资料下载Equipped with a lift, this unit is designed for large-volume steel vessels, e.g. in kilo labs. The lift can be operated electrically or manually for easy lifting, lowering, or tilting of the pressure vessels.
常用单位换算
简介:常见物理化学单位换算。方便在欧洲,中国,美国习惯单位之间转换。 重量,体积,压力,长度,面积,体积等等。。
控制仪品介绍
简介:可用于反应釜体相关的参数控制和记录 温度、压力、搅拌速度、粘度、PH等等。 如要实现自控请与我们联系
电热釜介绍
简介:3E 和 4E 型电子加热压力反应釜体积可从0.5 到 20升. 加热器内有整合的冷却管可精确快速的控制温度. 3E 和 4E 型电子加热压力反应釜体适用于ecoclave, polyclave and kiloclave.
世界一流的玻璃接口技术视频
简介:«büchiflex» - the flexible and modular glass system using standardized components allows for absolutely stress-free installation and makes it possible to assemble piping on a gradient without the need for any special componsators. This flexible tube connection system, extremely well suited for glass, forms the basis for the successful, safe and economic use of glass in piping. Aside from it's flexibility, it is also pressure tight, vacuum-tight, and easy to assemble.
详细介绍
简介:BüchiGlasUster 生产《chemReactors》, 搪玻璃搅拌槽之玻璃overheads 及适合您需要的玻璃管路; 无论那一种制程,材质,温度,测量科技, 自动化, 压力泛围–Büchi品牌代表完美的量身订造的解答,例如配搭搪玻璃,不锈钢,Hastelloy C22 或低温反应槽作低温或压力反应
