方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Contact angle measurements can determine the surface energy, , of a solid. To accurately measure the surface energy, we must use a set of fluids and the Lewis acid/base theory with the contact angles, q, for each fluid. However, a simple contact angle measurement with water will give an approximate answer. This is useful because almost all "contaminants" on a surface affect the measured surface energy. This connection is what we exploit when using contact angles.
THINKY搅拌脱泡-ARV310
THINKY搅拌脱泡-ARV10KT
THINKY搅拌脱泡-AR500
