方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
We report a force sensor based on a quartz crystal that is used for measuring nanoscale topographic images. The crystal is a length-extensional mode oscillator with a resonant frequency of about 650 kHz. Compared to 33 kHz tuning forks, such crystal sensors have a much higher resonance frequency, which allows for high force sensitivity and a fast response time. The crystal sensor is operated in the shear-force mode, with the probes vibrating parallel to the sample surface. The tip-sample interaction during operation is estimated to be less than 300 pN.
THINKY搅拌脱泡-ARV310
THINKY搅拌脱泡-ARV10KT
THINKY搅拌脱泡-AR500
