方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
We have studied the electronic properties, in relation to their structural properties, of monolayers of 1-octadecene attached on a hydrogen-terminated (111) silicon surface. The molecules are attached using the free-radical reaction between C=C and Si-H activated by an ultraviolet illumination. We have compared the structural and electrical properties of monolayers formed on silicon substrate of different types (n-type and p-type) and different doping concentrations from low-doped (~1014 cm-3) to highly doped (~1019 cm-3) silicon substrates. We show that the monolayers on n-, p- and p+-silicon are densely packed and that they act as very good insulating films at a nanometer thickness with leakage currents as low as ~10-7 A.cm-2 and high quality capacitance-voltage characteristics. The monolayers formed on n+-type silicon are more disordered and therefore exhibit larger leakage current densities (>10-4 A.cm-2) when embedded in a silicon/monolayer/metal junction. The inferior structural and electronic properties obtained with n+-type silicon pinpoint the important role of surface potential and of the position of the surface Fermi level during the chemisorption of the organic monolayers.
THINKY搅拌脱泡-ARV310
THINKY搅拌脱泡-ARV10KT
THINKY搅拌脱泡-AR500
