在线密度计资料
简介:DT-1型液体在线密度计,使用简单、读取数据方便快捷。该仪器可同时读出介质的温度和密度两个参数,方便行业标密换算。 产品由电容式差压传感器、压力中继器、温度传感器组成,温度传感器的作用是显示液体温度变化的 ,另配专用软件计算密度。 该产品可对各种液体或液态混合物进行在线密度测量,监控生产过程中液体 密度的变化,从而保证产品质量和各批产品的一致性。
压力源产品简介
简介:FYYLQ-6B手动气压源由加压泵、调压阀、微调阀、回检阀和输出接口等组成,密封性能好,升压平稳,操作简单,适合实验室及现场作业使用。可为校验压力(差压)变送器、精密压力表、普通压力表及其它压力仪器仪表提供压力。
密度计产品简介
简介:ZYMD—Ⅰ型智能液体密度计,是具有直接读数功能和恒温功能的新型液体密度计,它是由双音叉式密度传感器、振筒电路、测温电路、CPU、显示器恒温槽、进液泵及控制面板组成的只能化仪表。该仪器申请了两项国家专利,并通过了河北省科技厅新产品鉴定,其性能堪与国外同类产品媲美。
压力源产品简介
简介:压力校准、检定工作都离不开压力源。一个好的压力源应该做到加压省力,稳定快,兼顾的量程尽可能的宽。压力源从最早的解决实验室校准、检定工作,发展到兼顾实验室和现场检测工作,大大的减少了设备的重复购置。
智能液体密度计英文说明书
简介:ZYMD—1 intelligent liquid densimeter makes test on liquid density with vibration cylinder density transducer. Sample liquid is pumped into resonator transducer, and surveyed by single-chip processor to read out directly the density of liquid. It is featured in high sensitivity, less required sample, good repeatability as well as great convenience and velocity. Specific liquid, such as alcohol, may be processed by single-chip processor software to read out directly the data of volume concentration, making the test more convenient. This densimeter may be used widely for measure of liquid density, and direct readout of alcohol content, sulphuric acid concentration or specific gravity of other liquid such as fuel oil and lubricating oil. This apparatus is applicable for various density measure of chemical agents (except fluohydric acid), liquid food and beverage (those with carbonic acid need advance removal of sparkle), petroleum liquid products and other kinds of chemical liquid products.
