方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The high-temperature oxidation resistance of amorphous Zr–Si–N and W–Si–N films with a high Si content (20 at.%) deposited by reactive dc magnetron sputtering at different partial pressures of nitrogen was systematically investigated by means of a symmetrical high-resolution thermogravimetry in a flowing air up to an annealing temperature of 1300 8C (a temperature limit for Si(1 0 0) substrate). Additional analyses including X-ray diffraction (XRD), light optical microscopy (LOM), scanning electron microscopy (SEM), atomic force microscopy (AFM), and microhardness measurement were carried out as well. The obtained results showed (i) an excellent high-temperature oxidation resistance of the Zr– Si–N films up to 1300 8C, (ii) a considerably lower oxidation resistance of the W–Si–N films. The W–Si–N films are completely oxidized at 800 8C with a subsequent volatilization of unstableWOx oxides. On the other hand, the Zr–Si–N films are oxidized only very slightly on the surface, where a stable oxide barrier layer preventing further inward oxygen diffusion is formed. The thickness of the oxide layer is only about of 3% of the total film thickness. The phase composition, thermal stability of individual phases and amorphous structure were found to be key factors to achieve a high oxidation resistance.
STA表征硫化橡胶组分含量
STA测定尼龙66样品水分和挥发物含量
DSC评价发泡剂热危险性
