方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Two compounds formed with the same drug and two different excipients are analyzed : drug + lactose and drug + P.E.G. (Polyethyleneglycol). From the curve it is evident that the sample containing PEG as an excipient gives a much higher exothermic effect demonstrating a much lower compatibility.
STA表征硫化橡胶组分含量
STA测定尼龙66样品水分和挥发物含量
DSC评价发泡剂热危险性
