方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract Films may be considered as wide fibers, or as unique material geometry possessing two dimensional symmetry (X, YZ). Potentially different uniformity issues along the machine (long) and transverse directions of the film, characterization of Z-axis performance—especially as films become “thin” and the characterization/identification of surface modification, introduce the need for careful sampling strategies if the resulting thermal analysis data is to be reflective of either process history or end-use performance or both. Two dimensional imaging by a combination of techniques—i.e., DSC–WAXS–FTIR–AFM exploit the convenience of the sample geometry, while aiding in the definition of structural complexity. Molecular spectroscopy techniques (DMA, TSC) provide a sensitive and instructive tool for examining novel surface or interface chemistry. Characterization under biorelevant conditions (37 ◦C, aqueous, standard saline, presence of adhesive and other proteins, presence of cells) is critical for the generation of meaningful data on films to be utilized biologically (cell culture, tissue engineering substrates, biochips). Of special interest are strategies for accelerated aging that allow prediction of biological or biorelevant performance. © 2006 Elsevier B.V. All rights reserved.
STA表征硫化橡胶组分含量
STA测定尼龙66样品水分和挥发物含量
DSC评价发泡剂热危险性
