方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Lubricant that is used in compressors of freezer or cooler circulates the cooling circuit with the coolant (CFC-type coolant). The chlorine ion contained such lubricant and coolant may corrode the internal surface of piping and cause failure. This section introduces an example in which approximately 20g of sample was weighed precisely and dissolved in 100mL solvent mixture to be acidified with nitric acid for potentiometric titration with silver nitrate titrant. Cl-+ AgNO3 ——— AgCl + NO3- The amount of chlorides in freezer oils can be determined by silver nitrate titration method by dissolving the sample in organic solvents acidified with nitric acid.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
