方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Polyurethane has an excellent flexibility, adhesiveness and high impregnation rate, widely utilized such as automotive films, insulating materials, and paints. The polyurethane resin is a polymer which involves the urethane bond, obtained by the polymerization reaction between polyisocyanate and polyol (also called, polyester or polyether). ・・―NCO + HO―・・ ・・―NHCOO― … (1) ―NCO + H2N―・・ ・・―NHCONH― … (2) ・・H2N―(excessive) + HCl HCl・H2N― … (3) (B-D)×K×F×M S×1000 A1 : Content of isocyanate groups (%) F : Factor of the titrant D : Volume of the titrant consumed (mL) M : Molarity of the titrant (0.5) B : Blank value (mL) S : Weight of the sample added (g) K : Formula weight of isocyanate (42.02)
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
