方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The quantifications of total chromium (A) and chromic acid (B) can be carried out as described in this application note following the calculation formulae below. The amount of chromic anhydride can be obtained by subtracting the quantity of chromic acid from the blank test result (C). Chromic anhydride = (C) – (B) Trivalent chromium = (A) – (B)
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
