方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The quantities of sulfuric acid and copper contained in CuSO4 plating solution can be determined consecutively by using the COM-potentiometric Titrator with additional burets and suitable electrodes. Sulfuric acid is titrated with sodium hydroxide titrant first. And then potassium iodide is added in the status acidified by sulfuric acid to liberate iodine. The free iodine is finally titrated with sodium thiosulfate titrant to measure copper contained.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
