方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The determination of water in 2-propanol is very straightforward. In this application note, the volumetric method is applied because the water content is relatively high (% level). Some grades of 2-propanol contain very low water content (ppm level), recommendable to use coulometric KF titration method.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
