方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Water in resins can be determined by heat evaporation indirect titration with Coulometric Karl Fischer titrator AQ-2100/AQ-300 interfaced with Solid Evaporator EV-2000. By heating the sample at near its melting point, only water is evaporated and carried into the titration cell to be measured. This system is very effective to keep the anode solution in the cell and reduce the consumption of expensive KF reagents.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
