方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Chicken oil is not soluble in methanol but well soluble in chloroform or toluene. In Karl Fischer titration method, it is a key to find a suitable solvent to dissolve the sample and to extract water contained. This application note introduces two methods: one is directly inject the sample into chloroform-base solvent, and the other is using an oil evaporator to azeotropically remove the water from the sample and then deliver it into the titration cell.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
