方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Tar or bitumen samples contain a certain amount of moisture mixed inhomogeneously. In order to measure moisture content in such samples, it requires sonication and extraction using dehydrated THF (tetrahydrofuran) as extraction solvent for pretreatment prior to titration. In addition, by using the KF titrator in combination with the oil evaporator EV-2000L by azeotropic distillation method, a successful measurement of water in tar can be made without any interference by coexisting substances may bother KF reaction.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
