方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
By titrating with sodium hydroxide standard solution, sulfuric acid and aluminum ions contained in aluminum processing liquid for plating can be determined. In this titration, two inflection points are defined; the first point indicates the sulfuric acid content and the titrant consumption between first to second end points indicates the amount of aluminum ions according to the formulae 1 and 2 as shown below. H2SO4 + 2NaOH Na2SO4 + 2H2O … formula 1 Al3+ + 3NaOH 3Na+ + Al(OH)3 … formula 2
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
