方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Emulsifying aid in powder form is normally not soluble in anode solution, giving results with low repeatability if directly injected to the KF titration cell. For the determination of water content in such poorly-soluble compounds, using the EV-2000 Solid Evaporator is effective to evaporate only water to be measured by KF titration method. The optimum heating temperature should be studied prior to the measurement otherwise additional water will be produced by pyrolysis.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
