方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The method for determining sodium acetate which are utilized as alkali supplement and diuretic is typically based on perchloric acid titration in non-aqueous medium. The sample is dissolved in glacial acetic acid and then titrated with a solution of perchloric acid in glacial acetic acid. CH3COONa + HClO4 CH3COOH + NaClO4
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
