方案下载应用领域 | 建材/家具 |
检测样本 | |
检测项目 | |
参考标准 |
The determination of sulfite ions contained in gold plating solution can be performed by the following procedure: Add a certain amount of iodine solution to the sample solution to react with sulfite ions in the sample as indicated formula (1). After acidifying with hydrochloric acid, titrate the remaining iodine with sodium thiosulfate solution as shown in formula (2) by the redox back titration. SO32- + I2 SO42- + 2H+ + 2I- ・・・ (1) I2 + 2Na2S2O3 2NaI + Na2S2O6 ・・・ (2)
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
