在Versa mini PCR上进行测序反应的建立
2007-08-18 09:38  下载量:576
资料下载
Manual step: 1. Take out the reagents from freezer. Thaw them gently and place the tubes in the slots of cooling block on the VERSA100 deck. Automation steps: 2. Aspirate the required volume of each of the reagent number 1 to 4 (as shown in the table below) and dispense into the empty Master Mix (MM1) tube on the cooling block. Change tip for every reagent. 3. Mix the contents by pipetting twice with the tip in use. ... ...
资料下载
文献贡献者
相关资料 更多
当前位置: 欧罗拉生物 资料 在Versa mini PCR上进行测序反应的建立
