资料下载毛细管电泳应用于测定牛血清白蛋白与脂质体的相互作用 厉红,屈锋,徐建栋,邓玉林 北京理工大学生命科学与技术学院, 北京 100081 收稿日期 2008-2-21 修回日期 2008-7-30 网络版发布日期 2008-7-30 接受日期 2008-7-30 摘要 建立了一种用毛细管电泳法检测牛血清白蛋白(BSA)与脂质体相互作用的分析方法。氧化指数的测定实验结果表明经过冷冻干燥的脂质体稳定性更好;毛细管电泳表征脂质体的电荷性质实验结果表明脂质体在pH 5.0~8.0的条件下呈电中性。在pH 7.0的条件下,以各种浓度的脂质体混悬液为电泳缓冲液,以0.8%二甲亚砜(DMSO)为内标,随着缓冲液中脂质体质量浓度从0增加到2.4 mg/mL,BSA的有效淌度从-2.232×10-4 cm2·V-1·s-1变化到-3.046×10-4 cm2·V-1·s-1;结合Scatchard分析,测得BSA与脂质体的结合常数为2.522×103(g/mL)-1。该方法简单、快速,为研究蛋白质与脂质体的相互作用提供了新的技术手段。 关键词 毛细管电泳 牛血清白蛋白 脂质体 Investigation on interaction between bovine serum albumin and liposome using capillary electrophoresis LI Hong, QU Feng, XU Jiandong, DENG Yulin School of Life Science and Technology, Beijing Institute of Technology, Beijing 100081, China Abstract A method for the investigation on the interaction between bovine serum albumin (BSA) and liposome using capillary electrophoresis was developed. The oxidation index showed that the liposomes after freeze-drying were more stable. The results obtained from the capillary electrophoretic analysis of liposome showed that liposome had no charge at pH 5.0-8.0. A series of liposome suspension at different concentrations with the internal marker of 0.8% dimethyl sulfoxide (DMSO) were introduced as the electrophoresis buffer at pH 7.0. Along with the liposome concentrations raised from 0 to 2.4 mg/mL, it was found that the effective mobility of BSA changed from -2.232×10-4 cm2·V-1·s-1 to -3.046×10-4 cm2·V-1·s-1. The binding constant between BSA and liposome was 2.522×103(g/mL)-1 calculated by Scatchard analysis. This method is simple and rapid, and provides a new technology for the investigation on the interactions between protein and liposome. Key words capillary electrophoresis (CE) bovine serum albumin (BSA) liposome
恒温恒湿称重系统产品介绍
简介:国产化恒温恒湿称重系统MWS-2适用于手动称量低浓度采样头、采样滤膜及3#滤筒。该系统集合众多领先技术,可对处理对象进行恒温恒湿平衡,并进行后续的手动称重,整个过程都在封闭洁净环境下完成,能有效防止环境微尘的污染。同时可选配射频识别(RFID)读写功能,实现系统自动编写、识别和数据统计管理。
如何正确选择色谱柱
简介:色谱分析技术主要是应用在化学医药实验室或研究所等领域内,主要是用来分析液体或气体样品的内部成分情况。色谱柱是色谱分析系统中非常的关键的核心部件,它的作用是使得样品内部成分以不同的速率通过色谱柱,而让检测器检测通过色谱柱成分的各个不同色谱峰,最终确定其成分。下面我们来了解一下如何正确选择色谱柱。
气相色谱仪载气选择分析及使用注意事项
简介:气相色谱分析,肯定少不了“气”,就是载气。那么在气相色谱仪的使用过程中如何选择合适的载气呢?下面苏州莱顿带来气相色谱仪载气选择分析,一起来看看吧。
食品药品用包装材料的有机溶剂残留量检测
简介:磐诺仪器采用静态顶空气相色谱法,基于高灵敏度氢火焰离子化检测器,对包装材 料中 12 种常用有机溶剂残留量的测定进行了系统的方法学研究,建立了一种方便,快捷,高效的检测方法。
气相色谱仪进样口堵塞处理办法
简介:气相色谱仪进样口堵塞,最突出的表现即进样口压力值不断上升。堵塞容易造成分析样品重复性不好、实际压力大于设定压力等诸多问题,那么如何解决气相色谱仪进样口堵塞的问题呢?或者说气相色谱进样口堵塞怎么办?一起来了解一下吧。
Waters515液相色谱仪
UltiMate3000液相色谱基本系统
HTY-DI1000型水中总有机碳(TOC)分析仪
Waters1525二元梯度液相色谱仪
九成新二手热电 ICS-3000离子色谱仪
二手Agilent 6890-5973 GC/MS气质联用仪
二手岛津GCMS-QP2010气质联用仪
二手Agilent 7890A-5975C气质联用仪
二手安捷伦Agilent 1260液相色谱仪
二手岛津GC2010气相色谱仪
PTC-III型固/液吹扫捕集仪
安捷伦/Agilent8860气相色谱仪/FID/现货
二手Waters2695液相色谱仪
二手安捷伦Agilent1100液相色谱仪
二手安捷伦Agilent 6890N气相色谱仪
