方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
This paper presents a methodology to evaluate the stability of cockles in shallow estuaries for different hydrodynamic conditions. Two methodologies are proposed in order to determine the suitability of the different regions of the estuary for cockles. Considering the complexity of all the processes which determine the movement of cockles, the methodology proposed here is intended to be a first approach to the problem taking into account only hydrodynamic variables, although the inclusion of biological variables is being studied at the present time. The aim of this work is to stablish an objective criteria for comparing the stability of cockles in different parts of an estuary under different hydrodynamic conditions. In order to perform this analysis we have developed a cockle habitat model model which considers the hydraulic characteristics of cockles and the flow patterns in the estuary.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
