方案下载应用领域 | 医疗/卫生 |
检测样本 | 内脏器官 |
检测项目 | |
参考标准 | 暂无 |
The focus of this study is an experimental apparatus that serves as a model for studying blood flow in a total artificial lung (TAL), a prototype device intended to serve as a bridge to lung transplantation or that supports pulmonary function during the treatment of severe respiratory failure. The TAL consists of hollow cylindrical fibers that oxygen-rich air flows through and oxygen-poor blood flows around. Because gas diffusivity in the TAL is very small, a convection mechanism dominates the gas transport, which is why we focus on the velocity around the fibers (modeled as a 0.05-cm-in-diameter and 5-cm-long cylinder). We designed a low-speed water tunnel to study the flow mechanism around the cylinder, across which the flow is generated by a linear actuator that allows different flow patterns to mimic the flow in a TAL. We tested the flow in the test section by numerical simulation and by the particle image velocimetry method to study the flow profile. The results show a uniform flow near the centerline of the water tunnel where the cylinder is placed. This decreases the effects of free-stream turbulence in the shear layers and reduces the uncertainty in determining the flow patterns around the cylinder. Knowledge gained from the flow around one cylinder (fiber) is beneficial for understanding vortex formation around multiple cylinders. We present a summary of vortex formation behind a cylinder for Reynolds numbers (Re) of 1, 3, and 5 and Stokes numbers (Ns) of 0.18 to 0.37; results show that higher Re and Ns favor vortex formation. These findings regarding the parameter range for vortex formation may provide principles for designing artificial lungs to enhance convective mixing. We anticipate that the pulsatile flow circuit presented here can be used to mimic the flow not only in TALs but in other physiological systems.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
