方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的DaVis7.2版数字图像相关DIC分析软件和ImagerProX4M制冷型带相机头内存14比特高性能CCD相机构成的测试系统,测量分析材料疲劳断裂测试过程中的J积分参量。
This paper presents a combined experimental-numerical technique for the calculation
of the J-integral as an area integral in cracked specimens. The proposed technique is
based on full-field measurement using digital image correlation (DIC) and the Finite
element method. The J-integral is probably the most generalised and widely used
parameter to quantify the fracture behaviour of both elastic and elastoplastic
materials. The proposed technique has the advantage that it does not require crack
length measurements nor is it limited to elastic fracture mechanics, provided that only
small scale yielding is present. Evaluated are three test geometries; compact tension,
three-point bend and the double torsion beam. Possible errors and their magnitude
and the limitations of the method are considered.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
