方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用立陶宛Ekspla公司的皮秒振动和频光谱测量系统(VS-SFG)对酶、非酶分子的表面化学,光谱学特性进行了实验研究并讨论了其可能的应用。
The content of this thesis is an investigation into physicochemical, photophysical,
and interfacial properties of β-galactosidase, a crucial enzyme, its conjugate with CDs,
interaction of β-galactosidase with X-gal, and surface chemistry and spectroscopic study
of toxins, Cholera toxin B (CTB) and Fumonisin B1 (FB1). The objective of the work was
to understand the surface chemistry behavior of the important enzyme, conjugates and
toxins in a model systems representing vaguely cell membrane environments, to prove the
activity of the deposited enzyme, its conjugate, and toxins in a form of the monolayer. We
also studied the effect of green LED light on the FB1 Langmuir monolayer which will be
useful for possible future treatment of fungal keratitis without any side effects. Furthermore, this approach can be employed to understand the property of transmembrane receptors, to study the cell adhesion, and its implications. Besides that, this information is relevant for the successful deposition of Langmuir-Blodgett (LB) film. The Langmuir monolayer isotherm of enzyme, conjugate and the toxin were studied using the surface chemistry and spectroscopy at the air-water/subphase interphase.
We employed the pressure (π)-area (A) isotherm measurement which is typically
the very first step in the study of these enzymatic and non-enzymatic molecules floating at
the subphase surface as it gives useful information on the existence of different phases,
phase transitions and the stability of Langmuir monolayer at fixed temperature and pH.
During our study we found that β-galactosidase as well as its conjugate form stable
Langmuir monolayer. We observed that during the interaction of the enzyme with X-gal,
its secondary structure changes. This does not mean that the overall structure of the enzyme
gets changed. This is because enzyme structure is determined by primary, secondary,
tertiary, and quaternary structure. The interfacial study of CTB showed that the molecule
is very stable at the air-subphase interface. In performing surface chemistry and
spectroscopic study of FB1 molecule, the interesting finding that came out of the FB1
Langmuir monolayer investigation was that the analyte adopted stability (without
irradiation of green LED light) at the monolayer and remained degraded with subsequent
effect of the green LED light (525 nm) at air-water interface.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
