方案下载应用领域 | 电子/电气 |
检测样本 | 电子元器件产品 |
检测项目 | |
参考标准 | 暂无 |
采用立陶宛Ekspla公司纳秒激光泵浦光学参量振荡器NT342A-10,输出激光10Hz, 波长860nm,结合1台150W连续氙灯研究了近红外光电探测器瞬态光伏弛豫性能。
Near-infrared (NIR) photodetectors sensitive to 860 nm light were fabricated through a solution process using two different conjugated polymers (CPs) that share a similar conjugated backbone consisting of a diketopyrrolopyrrole (DPP) moiety. The two CPs had a comparable conjugated nature, but their detection capabilities were significantly different depending on the applied linker units, namely thiophene for PDPP-T and fluorinated
thiophene for PDPP-FBT. First, we revealed that employing an additive during active film preparation was beneficial for achieving an optimum film morphology for both CPs, which could suppress dark current and provide enhanced detectivity. In addition, when a highly electronegative fluorine atom, which induces a surface dipole, was introduced into the conjugated skeleton, it was clearly demonstrated via transient photovoltage measurements that the charge recombination time was lengthened, which implies an increase in the probability of charge extraction in actual devices by suppressing charge recombination. Thus, PDPP-FBT exhibited higher external quantum efficiency and responsivity across all wavelengths. Our results indicated that the management of both film morphology and surface dipoles of CPs are equally important for achieving high detectivity and responsivity in organic NIR photodetectors.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
