方案下载应用领域 | 交通 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采德国LaVision公司的两相机2D3C立体PIV测量系统和集成一体化的4台相机构成的MiniShaker测试系统,对水下导管螺旋桨尾流流场进行了测量和理论分析。
Understanding the interaction of ship, propulsor and waterway is of utmost importance in inland navigation. Regulations and waterway maintenance rely on assumptions for the potential for damage of banks and beds by the propeller wake. Scours for example occurring close to ports and locks where ships need great thrust shall be avoided or repaired at an early stage.
Computational Fluid Dynamics are becoming more and more mature and are already applied for numerous flow phenomena. Especially, in turbulent flows with coherent vortex structures there is still a large demand for validation data and improved computational methods.
3C Particle Image Velocimetry is a powerful non-invasive laser-based method for the measurement of fluid flows. Here all three velocity components are measured simultaneously within a thin light sheet resolving the flow in a 2D plane. However, for many applications and the deeper understanding of transient 3D flows it is desired to measure simultaneously in a volume. Previous 3D particle tracking velocimetry systems suffered from a low resolution and difficulties with a higher density of tracer particles.
The novel system used here to measure the propeller wake behind ducted propellers tries to overcome these disadvantages with the tracking algorithm Shake-the-Box and a new hardware design for straightforward and reliable calibration. The focus of this paper is on a comparison of the new volumetric flow measuring technology with conventional 3C Particle Image Velocimetry. The test case is the wake of a ducted propeller in bollard pull condition.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
