方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车涂层和镀层 |
检测项目 | 尺寸测量>涂层/镀层厚度 |
参考标准 | 暂无 |
采用LaVision公司由4台sCMOS型相机和DaVis8.2软件平台构成的大视场2D2C粒子成像测速系统,对破漏层模型的流程进行了初步的实验分析。
Accurate and reliable experimental data of a sloshing-induced, rapidly-evolving spilling breaker, are used to understand the specific physics of this phenomenon and to partially evaluate a simplified analytical model by Brocchini and co-workers (Brocchini , 1996; Misra et al., 2004, 2006). Such model is based on a three-layer structure: an underlying potential flow, a thin, turbulent single-phase layer in the middle and a turbulent two-phase layer (air–water) on the upper part. The experiments were carried out by using a 3 m long, 0.6 m deep and 0.10 m wide tank, built in Plexiglas and forced through an hexapode system, this allowing for an high accuracy of the motion. Mean and turbulent kinematic quantities were measured
using the Particle Image Velocimetry (PIV) technique. To ensure repeatability of the henomenon, a suitable breaker event was generated to occur during the first two oscillation cycles of the tank. The tank motion was suitably designed using a potential (HPC) and a Navier–Stokes solver. The latter, was useful to understand the dimension of the area of interest for the measurements. The evolution of the breaker is described in terms of both global and local properties. Wave height and steepness show that after an initial growth, the height immediately decays after peaking, while the wave steepness remains constant
around 0.25. The evolution of the local properties, like vorticity and turbulence, vortical and turbulent flows displays the most interesting dynamics. Two main stages characterize such evolution. In stage (1), regarded as a ‘‘build-up’’ stage, vorticity and TKE rapidly reach their maximum intensity and longitudinal extension. During such stage the thickness of the single-phase turbulent region remains almost constant. Stage (2), is regarded as a ‘‘relaxation’’ stage, characterized by some significant flow pulsation till the wave attains a quasi-steady shape. In support to the analytical, three-layer model of Brocchini and co-workers it is demonstrated that the cross-flow profile of the mean streamwise velocity U inside the single-phase turbulent layer is well represented by a cubic polynomial. However, differently from available steadystate models the coefficient of the leading-order term is function of time: A = A(s, t). During stage (1) a fairly streamwise-uniform distribution of U is characterized by A(s, t) ≈ 1, while during stage (2) U is less uniform and A varies over a much larger range.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
