方案下载应用领域 | 交通 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVison公司的粒子成像测速系统(PIV),对波浪和水流联合作用下双桩局部冲刷的流场进行了实验测量。
Under the actions of ocean waves and current, severe local scour can be induced around pile groups, significantly compromising the safety of marine structures. A series of flume tests were conducted for physical modelling the local scouring process around twin piles in the cohesionless soils under combined waves and currents, and compared with the pure current case. The effects of non-dimensional pile spacing (G/D) and flow skew angle (α) on the scour depth and time scale of scour around twin piles are intensively examined. The experimental observations indicate that the influence of pile spacing on the scour depth development is much more significant for the side-by-side (α=90ο) arrangement than that for the tandem arrangement (α=0°). With the increase of flow skew angle α, the maximum scour depth is remarkably enhanced within the examined range 0 G/D 3.0. When G/D=3.0, the pile group effect on the time scale is generally negligible for pure current cases, whereas a prominent pile-group effect can still be observed for combined wave-current cases, especially for the side-by-side arrangement. A parameter of "equivalent pile diameter" is then introduced for evaluating the maximum scour depth at the twin piles with the previous formulas for the single pile. Based on the existing and present experimental data, the empirical formula of dimensionless equivalent pile diameter as the function of G/D and α is established to predict the maximum scour depth at the twin piles.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
