方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVison公司的StrainMaster系统,对小块超弹性样品材料的材料力学特性以及全场应变特性进行了测量研究。
The aim of this research was to develop and test an experimental method,
which could be scaled to samples of 4 mm x 4 mm x 1-2 mm in size. To
validate the design of the experimental method, it was applied to samples
(10 mm by 10 mm by 2.5 mm in size) of a soft hyperelastic silicone-rubber
using available equipment.
The biggest challenge in this research was the small scale at which testing
was performed. In addition, the size of force measurements was small (under
10 N), which meant that force measurements inherently included noise, which
could not be neglected.
The method was designed such that stress concentrations were avoided and
boundary conditions were simple enough to be easily implemented in a finite
element analysis. A uni-axial compression test was performed where full-field
displacement data was measured using digital image correlation and force data
was measured using a 50 N load cell. Displacement and force results for compressions
of between 20-55 % of the height of the sample were used in an
inverse finite element model updating method to iteratively determine a three
parameter Mooney-Rivlin material model for the hyperelastic silicone-rubber.
There was a large amount of variability in the force results, even though the
displacement inputs for the tests were repeatable. The inverse finite element
model updating method showed repeatability in the value to which it converged,
however the material model obtained from the optimization process
produced accurate displacements neither when plotted against the experimental
displacements nor when implemented in a validation test geometry.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
