方案下载应用领域 | 航空航天 |
检测样本 | 航天 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司由科研型CMOS相机和DaVis软件平台构成的粒子成像测速系统,对在泰勒-库埃特湍流中,使用疏水内筒实现气泡减阻的方法进行了实验测量研究。
In this study we experimentally investigate bubbly drag reduction in a highly turbulent flow of water with dispersed air at 5:0 105 6 Re 6 1:7 106 over a non-wetting surface containing micro-scale roughness. To do so, the Taylor–Couette geometry is used, allowing for both accurate global drag and local flow measurements. The inner cylinder – coated with a rough, hydrophobic material – is rotating, whereas the smooth outer cylinder is kept stationary. The crucial control parameter is the air volume fraction present in the working fluid. For small volume fractions ( <4 %), we observe that the surface roughness from the coating increases the drag. For large volume fractions of air ( >4 %), the drag decreases compared to the case with both the inner and outer cylinders uncoated, i.e. smooth and hydrophilic, using the same volume fraction of air. This suggests that two competing mechanisms are at play: on
the one hand, the roughness invokes an extension of the log layer – resulting in an increase in drag – and, on the other hand, there is a drag-reducing mechanism of the hydrophobic surface interacting with the bubbly liquid. The balance between these two effects determines whether there is overall drag reduction or drag enhancement. For further increased bubble concentration D 6% we find a saturation of the drag reduction effect. Our study gives guidelines for industrial applications of bubbly drag reduction in hydrophobic wall-bounded turbulent flows.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
