百灵威是全球化集成式科技与工业资源平台,为g内政府机构、科研院所和第三方检测企业等提供c过50,000种各类标准品,涉及环境、食品、石化、医药、农药、电子、烟草和无机等各个检测l域和环节;并已为客户定制c过10,000种混标。百灵威AccuStandard质量体系已通过ISO 9001: 2015认证,并获得了ISO 17034和ISO/IEC 17025的认可。
百灵威标样种类全、现货数量足,并y站式供应分析试剂和仪器耗材,全面、快速满足分析检测实验室需求。
权威认证yj标准品,确保检测结果准确
专属定制混标
j速送达,20,000瓶g内现货,4小时发运
部分GB、Hj方法适用标准品
适用标准 | 名称 | 货号 |
HJ 1021 | Custom hydrocarbon standard @ varied conc.in hexane 正癸烷与正四十烷窗口标液 | |
HJ 997 | Option 2 Testing Mix@1000 μg/mL in Acetonitrile 15种醛酮混标 | |
Option 2 DNPH Derivative Testing Mix@0.1 mg/mL in AcCN 15种醛酮-DNPH混标 | ||
HJ 970 | Hydrocarbon Window Defining Standard@500 μg/mL in Chloroform 烃窗口界定标样 正构烷烃C8~C40 | |
HJ 977 | Custom Standard @ 1000 μg/mL in Methanol 2种氯化烷基汞混标 | |
HJ 952 | PBDE Congeners of Primary Interest@Varied conc. in Isooctane:Toluene (80:20) PBDE8种混标 | |
HJ 891 | 2,2',4,4',5,5'-Hexabromobiphenyl @ 100 μg/mL in Hexane 2,2',4,4',5,5'-六溴联苯 | |
HJ 835 HJ 912 | Custom Pesticide Standard @ 1000 μg/mL in 50% Hexane 50% Toluene 23种有机氯混标 | |
HJ 834 | AccuGrand 8270 Semi-Volatile Standard@1000 μg/mL in Dichloromethane:Benzene (75:25) 半挥发性有机物64种混标 | |
HJ 716 | Custom Nitrated Standard @ 100 μg/mL in Hexane:Toluene (50:50) 15种硝基苯混标 | |
HJ 922 | Custom Combined Congener Standard @100 μg/mL in Toluene 18种多氯联苯 | |
HJ 715 | Custom Labeled PCB Standard @ 100 μg/mL in Hexane 2种氘代多氯联苯替代物 | |
HJ 715 HJ 743 | Custom Combined Congener Standard @ 100 ug/mL in 100% Hexane 18组分多氯联苯 | |
HJ 715 | Custom Labeled PCB Standard @ 100 μg/mL in Hexane 2种氘代多氯联苯内标 | |
HJ 699 | Custom Mixed Analyte Standard @100 μg/mL in 95% Hexane 5% Acetone 8种氯苯+26种有机氯 | |
HJ 679 | Custom VOC Additions Standard 定制VOC混标(乙醛、丙烯醛、丙烯腈) | |
HJ 679 | Custom VOC Standard @ 2000 μg/mL in Water 定制3组分VOC混标(乙腈,丙烯腈,丙烯醛) | |
HJ 646 HJ 1023 | Internal Standard Mix@2.0 mg/mL in CH2Cl2 6种半挥发物氘代多环芳烃内标 | |
HJ 646 | PAH Mix 16组分多环芳烃混标 | |
HJ 605 | Method 502.2 - Volatile Organic Compounds@0.2 mg/mL in Methanol 60种VOC混标 | |
HJ 639 | 57组分挥发性有机物混标 | |
HJ 605 | Method 502.2 - Volatile Organic Compounds@2.0 mg/mL in MeOH 有机挥发物60种混标 | |
HJ 592 | 2,4,6-trinitrobenzoic acid at 1000 ug/mL in Methanol 2,4,6-三硝基苯甲酸 | |
GB 5749 | Custom OP Pesticide Standard 100 μg/mL in MeOH 7种有机磷农药混标 | |
GB 3838 | Custom Mixed VOC Standard@ Varied conc. In Methanol 25组分挥发性有机物标准品 | |
GB 3838 | Custom Mixed SV Standard 500 μg/mL in Toluene 24组分半挥发物混标 | |
GB 36600 | Custom Hydrocarbon Standard in n-Hexane 31种正构烷烃C10-40混标 | |
GB 36600 | Custom SV Standard @ 1000μg/ml in Mehtylene chloride SVOC混标C | |
GB 16886.7 | Ethylene oxide@5 mg/mL in Isooctane 环氧乙烷 | |
EPA 8270 | Method 8270 - Surrogate Standard@4.0 mg/mL in CH2Cl2 EPA方法8270标准替代物标样 | |
EPA 8270C/D | AccuGrand 8270 Semi-Volatile Standard@1000 μg/mL in Methylene chloride ASL方法8270C/D-39种混标 | |
EPA 8270 | Internal Standard Mix@4.0 mg/mL in CH2Cl2 6种半挥发物氘代PAH内标 | |
EPA 8260B | Surrogate Standard Mix@0.2 mg/mL in MeOH 挥发性有机物3种替代物 | |
烟草检测 | Custom Labeled Nitrosamine Standard @ 1000 μg/mL in Methanol 亚硝胺内标 | |
烟草检测 | Custom Labeled Nitrosamine Standard 100 μg/mL Methanol 亚硝胺混标 | |
烟草检测 | Custom Nitrosamine Standard 500 μg/mL in Acetonitrile 亚硝胺混标 | |
烟草检测 | Custom Nitrosamine Standard @1000 μg/mL in Acetonitrile 乙腈中亚硝胺标准 | |
有机氯检测 | Custom Pesticide Standard 8种有机氯农药混标 | |
RoHS 2.0 | Custom PBB & PBDE Standard@100 μg/mL in Toluene 20组分多溴联苯及多溴联苯醚混标 | |
RoHS 2.0 | Custom PBDE Standard 10种多溴联苯醚混标(1-10溴) | |
RoHS 2.0 | Custom Brominated Biphenyl RoHS Standard @100 μg/ml in 75% Toluene 25% Isooctane 定制10组分多溴联苯混标 | |
RoHS 2.0 | 2,2',3,3',4,4',5,5',6-Nonabromodiphenyl ether@50 μg/mL in Isooctane 2,2',3,3',4,4',5,5',6-九溴联苯醚 | |
RoHS 2.0 | Custom PBDE Standard 100 μg/mL Toluene 10种多溴联苯醚混标(1-10溴) | |
RoHS 2.0 | PBB MIX 7种多溴联苯混标(1-6溴和10溴) | |
RoHS 2.0 | 2,2',3,4,4',5,5',6-Octabromodiphenyl Ether@50 μg/mL in Isooctane 2,2',3,4,4',5,5'6-八溴联苯醚 | |
RoHS 2.0 | Bis(4-Methylpentyl)phthalate 邻苯二甲酸双(4-甲基戊基)酯 |
更多产品,请致电客服热线:400-6667788
相关阅读:2020年新实施环境标准(点击查看)
● HJ 1082-2019 土壤和沉积物 Cr(VI)测定 碱溶液提取 AAS法
● HJ 1079-2019 固定污染源废气 氯苯类化合物的测定 GC法
● HJ 1076-2019环境空气 4种胺的测定 离子色谱法
● HJ 1074-2019水质 4种有机锡的测定 HPLC-ICP-MS法
● HJ 1070-2019水质 15种氯代除草剂的测定 GC法
7A级抗菌+神仙颜值!这才是属于你的“白衣战袍”
百灵威【8月满赠】活动
春树计划之论文奖励——共建科研之森!
3分钟,评估您实验室的安全等级!
数显不锈钢加热磁力搅拌器套包装【907967】
高通量经济型核磁管
数显不锈钢加热磁力搅拌器【1122416】
活性碳/乙酰化炭黑
氯化铑(III)
二恶英(标准品)Dibenzo-p-dioxin , 50 μg/mL in Isooctane
二氯甲烷中23种氯苯与氯甲苯混标100mg/L(EN 17137)
4-[6-[13-[2-(2,4-二羧基苯基)-5-甲氧基-1-苯并呋喃-6-基]-1,4,10-三氧杂-7,13-二氮杂环十五碳-7-基]-5-甲氧基-1-苯并呋喃-2-基]苯-1,3-二甲酸
5-(4,6-二氯三嗪)氨基荧光素
7-(二甲基氨基)-2-氧代-2H-1-苯并吡喃-4-乙酸 2,5-二氧代-1-吡咯烷基酯
N,N'-二丹磺酰-L-胱氨酸
O-(4-硝基苯基磷酰基)胆碱
反-4-[4-(二甲氨基)苯乙烯基]-1-甲基吡啶对甲苯磺酸
L-谷胱甘肽(氧化型)
钠离子载体III
