人工湿地污染地下水处理生物降解一氯代苯
2010/12/27   下载量: 44
方案下载
应用领域
检测样本
检测项目
参考标准
The degradation of monochlorobenzene (MCB) was assessed in a constructed wetland treating MCB contaminated groundwater using a detailed geochemical characterisation, stable isotope composition analysis and in situ microcosm experiments. A correlation between ferrous iron mobilisation, decreasing MCB concentration and enrichment in carbon isotope composition was visible at increasing distance from the inflow point, indicating biodegradation of MCB in the wetland. Additionally, in situ microcosm systems loaded with 13C-labelled MCB were deployed for the first time in sediments to investigate the biotransformation of MCB. Incorporation of 13C-labelled carbon derived from the MCB into bacterial fatty acids substantiated in situ degradation of MCB. The detection of 13C-labelled benzene indicated reductive dehalogenation of MCB. This integrated approach indicated the natural attenuation of the MCB in a wetland system. Further investigations are required to document and optimise the in situ biodegradation of MCB in constructed and natural wetland systems treating contaminated groundwater.
方案下载
配置单
上一篇 拉曼测量
下一篇 圣安德鲁斯大学使用NANOSIGHT纳米颗粒跟踪分析仪用作外泌体特性研究
文献贡献者
相关方案
当前位置: 科艺仪器 方案 人工湿地污染地下水处理生物降解一氯代苯
