资料下载密度/(g/cm3) 材料 密度/(g/cm3) 材料 0.8 硅橡腔(可用二氧化硅填充到1.25) 1.19~1.35 增塑聚氯乙烯(大约含有40%增塑剂) 0.83 聚甲基戊烯 1.20~1.22 聚碳酸酯(双酚A型) 0.85~0.91 聚丙烯 1.20~1.26 交联聚氨酯 0.89~0.93 高压(低密度)聚乙烯 1.26~1.28 苯酚甲醛树脂(未填充) 0.91~0.92 1-聚丁烯 1.26~1.31 聚乙烯醇 0.9~0.93 聚异丁烯 1.25~1.35 乙酸纤维素 0.92~1.00 天然橡胶 1.30~1.41 苯酚甲醛树脂(填充有机材料:纸,织物) 0.92~0.98 低压(高密度)聚乙烯 1.30~1.40 聚氟乙烯 1.01~1.04 尼龙12 1.34~1.40 赛璐珞 1.03~1.05 尼龙11 1.38~1.41 聚对苯二甲酸乙二醇酯 1.04~1.06 丙烯腈-丁二烯-苯乙烯共聚物(ABS) 1.38~1.50 硬质PVC 1.04~1.08 聚苯乙烯 1.41~1.43 聚氧化甲烯(聚甲醛) 1.05~1.07 聚苯醚 1.47~1.52 脲-三聚氰胺树脂(加有有机填料) 1.06~1.10 苯乙烯-丙烯腈共聚物 1.47~1.55 氯化聚氯乙烯 1.07~1.09 尼龙610 1.50~2.00 酚醛塑料和氨基塑料(加有无机填料) 1.12~1.15 尼龙6 1.70~1.80 聚偏二氟乙烯 1.13~1.16 尼龙66 1.80~2.30 聚酯和环氧树脂(加有玻璃纤维) 1.10~1.40 环氧树脂,不饱和聚酯树脂 1.86~1.88 聚偏二氯乙烯 1.14~1.17 聚丙烯腈 2.10~2.20 聚三氟-氯乙烯 1.15~1.25 乙酰丁酸纤维素 2.10~2.30 聚四氟乙烯 1.161.20 聚甲基丙烯酸甲酯 1.17~1.20 聚乙酸乙烯酯 1.18~1.24 丙酸纤维素
汽车车身涂层抗石击性试验及评价方法
简介:涂层抗石击性检测是对整个涂层体系的力学性能进行的综合评价,能够反映涂层柔韧 性、各层间附着力和配套性的优劣,也是评价涂层二次力学性能极为重要的检测项目之一。国内外 汽车制造商所采用的抗石击性检测方法不统一。介绍了两种常用的涂层抗石击性试验方法及其评价 体系,并分析、比较了各自的优、缺点。
上岛吉曼扭转试验机-图像
简介:Rubber loses resiliency as temperature goes down. The frozen rubber can't keep its essential characteristics under the temperature below Glass Transition Point. In fact , the rubber applications under severe environments such as vehicle tire in frozen area and aircraft components in the stratosphere are seriously affected. It is a vital importance with the rubber applicants to test low temperature characteristics of vulcanized rubber. Our Gehman's torsion tester is the most popular testing machine for this purpose and is adopted by JIS K6261(Equivalent to ISO 1432)for low temperature testing method of vulcanized rubber. The Model TM-2531 satisfies performance requirements specified by the standard JIS K6261, and equips with the exclusive use frozen machine. It is also designed to perform measurement and data processing in a full automatic for easier operation.
CCD德黑西亚屈曲试验机详细说明书
简介:主要特点: ○设定摄影次数、直到结束次数为止连续地自动运转。 ○测定裂痕长度、可选择自动或手动、难以区别的试验片等可以在试验以后进行裂痕长度的修正。 ○鲜明的图像(图像分辨率0.1 ㎜)。 ○画各试验片的S-N曲线、试验结果保存到CSV文件夹里去。 ○试验片安装到夹具时、标准装备有效旋转方向盘。
全自动粘弹性分析仪
简介:与金属等弹性体不同,高分子材料是粘弹性体。物质只要施加以作用力,就会变形。金属等弹性体,施以作用力(应力)的同时就会产生变形(应变);相反,对于高分子材料来说,应力和应变不会在同一时间发生。这种关系随着测试样品的成分不同而不同,同时,也对温度、速度以及变形量等有依存性。由于这些差异,高分子材料被广泛应用于各个领域。
2013年合成橡胶价格走势偏弱
简介: 2012年上半年世界合成橡胶供应及需求增速同比均有小幅下滑,下半年需求增速有所加快,预计全年需求1537万吨,比2011年增长2.7%。2013年全球合成橡胶需求将达1594万吨,增速加快。 世界橡胶研究组织(IRSG)的数据显示,2012年1~6月,全球合成橡胶产量为750.7万吨,同比减少1.2%;消费量为751.6万吨,同比减少0.4%。 就我国来看,2012年下半年,国内合成橡胶新增能力明显增多,其中顺丁橡胶及丁苯橡胶分别新增36万吨和28万吨。到2012年末,顺丁橡胶和丁苯橡胶的总产能分别达到132.5万吨和159.2万吨。到2012年末,国内合成橡胶总能力为467万吨/年,年内新增114万吨/年。 2013年,合成橡胶的产能继续增多,顺丁橡胶及丁苯橡胶再增40万吨/年和15万吨/年。考虑到原料供应、下游需求、新增能力等状况,预计2013年上述两个品种产量分别为136万吨和92万吨,比2012年分别增长15.3%和19%,装置利用率下降。 2013年,合成橡胶需求将继续增长,但增速与2012年持平或略低。
转向装置耐久试验机
日本上岛制作所CCD德墨西亚疲劳试验机FT-1515
日本岩崎电气株式会社超级UV试验机SUV-W262
日本岩崎电气株式会社超级氙灯老化试验机XER-W83
上岛制作所轮胎帘线疲劳试验机FT-4151
日本岩崎电气株式会社 -超级紫外线老化试验机SUV-W161
日本SANWA SWITCH三和压力开关SPS-8T
低温脆化试验机
上岛制作所-TR恢复试验机TM-3525
日本上岛制作所RTM摩擦试验机FR-7225
韩国太成TSA-103自动弹出抽屉式烘箱
韩国太成TSA-102自动弹出抽屉式烘箱
韩国太成TSA-101自动弹出抽屉式烘箱
日本板桥理化复合循环腐蚀试验机BQ型
日本板桥理化中性盐水喷雾试验机SQ型
