方案下载应用领域 | 环保 |
检测样本 | 土壤 |
检测项目 | 有机污染物>多氯联苯/氯苯类化合物 |
参考标准 | HJ 743-2015 土壤和沉积物 多氯联苯的测定 气相色谱-质谱法;土壤和沉积物 毒杀芬的测定 气相色谱-三重四极杆质谱法(征求意见稿) |
This standard operating procedure (SOP) is applicable to the determination of organochlorine pesticides with the possible presence of polychlorinated biphenyls (PCBs) or toxaphene in soil/sediment matrices using a gas chromatograph (GC) with a narrow-bore fused silica column and an electron capture detector (ECD). This SOP is based on Environmental Protection Agency (EPA) Methods SW846/3500B/3540C/3541/8000B/8081A and those requirements set forth in the latest approved version of the National Environmental Laboratory Accreditation Committee (NELAC) Quality Systems section. Gel permeation chromatography [GPC] cleanup is required and is based on EPA/SW-846 Methods 3600C/3640A. Extracts may be subjected to optional cleanup procedures (florisil, tetrabutylammonium [TBA] sulfite or activated copper powder) based on EPA/SW-846 Methods 3600C/3620B/3660B. The compounds of interest and typical reporting limits (RLs) in soil/sediment matrices are found in Table 1, Appendix A.
This standard operating procedure (SOP) is applicable to the determination of organochlorine pesticides with the possible presence of polychlorinated biphenyls (PCBs) or toxaphene in soil/sediment matrices using a gas chromatograph (GC) with a narrow-bore fused silica column and an electron capture detector (ECD). This SOP is based on Environmental Protection Agency (EPA) MethodSW846/3500B/3540C/3541/8000B/8081A and those requirements set forth in the latest approved version of the National Environmental Laboratory Accreditation Committee (NELAC) Quality Systems section. Gel permeation chromatography [GPC] cleanup is required and is based on EPA/SW-846 Methods 3600C/3640A. Extracts may be subjected to optional cleanup procedures (florisil, tetrabutylammonium [TBA] sulfite or activated copper powder) based on EPA/SW-846 Methods 3600C/3620B/3660B. The compounds of interest and typical reporting limits (RLs) in soil/sediment matrices are found in Table 1, Appendix A.
工业园区污水及经生物反应器处理后的污水氨氮、有机氮及化学需氧量(COD)的测定
使用格哈特凯氏定氮仪测定药用汉麻(大麻)中氮含量
使用格哈特凯氏定氮仪测定水溶性复合氮磷肥料NPF中氮含量
