方案下载应用领域 | 农/林/牧/渔 |
检测样本 | 饲料 |
检测项目 | 营养成分>粗脂肪, 粗蛋白 |
参考标准 | GB/T 6432-2018饲料中粗蛋白的测定凯氏定氮法;GB∕T 6433-2006饲料粗脂肪测定方法 |
Total nitrogen was determined following the Kjeldahl method (Kjeldatherm, Vapodest 500,Gerhardt, K?nigswinter, Germany) to calculate the crude protein value using conversion factors 6.25. 使用格哈特公司 凯道森Kjeldatherm消化系统, 维普得Vapodest 500全自动凯氏定氮仪测氮含量,按6.25算蛋白质含量。 For fat determination samples were disintegrated for 30 min in 2 mol/L HCl, filtered, washed neutral and dried for2 h at 105℃. The fat was extracted automatically with n-hexane in a Soxtherm system (Gerhardt, K?nigswinter, Germany) and the content was determined gravimetrically. 脂肪分析:样品采用2 mol/L 盐酸水解半小时,过滤,洗涤到中性并在105℃下干燥2小时,然后用正己烷在格哈特公司的索克森Soxtherm 自动快速索氏提取仪进行脂肪提取,脂肪含量使用重量法检测。
Black soldier flfly larvae (Hermetia illucens, Diptera: Stratiomyidae) are used for the bioconversion of organic side products into valuable compounds such as proteins, lipids and chitin. However, the economic competitiveness of farmed insects compared to conventional protein production systems in agriculture and aquaculture depends on the availability of large quantities of inexpensive insect feed. Cottonseed press cake (CPC) is a side-stream of cotton production that is rich in proteins and lipids but unsuitable as feed for several farmed animals, except ruminants, due to the presence of the anti-nutritional sesquiterpenoid gossypol. Here, we tested CPC as a feed for black soldier flfly larvae and studied the impact of this diet on the gut microbiome. Larvae reared on CPC developed normally and even showed a shorter life-cycle, but were smaller at the end of larval development than control larvae reared on chicken feed. The adaptability of the larvae to different diets is mediated by their versatile gut microbiome, which facilitates digestion and detoxifification. We therefore used amplicon sequencing to analyze the bacterial and fungal communities associated with larvae reared on each diet, revealing differences between the larval guts and frass (residual feed substrate) as well as differences between the two diet groups. For example, Actinomycetaceae and Aspergillaceae were signifificantly enriched in guts of the CPC diet group and may help to metabolize compounds such as gossypol. Potentially probiotic yeasts and benefificial Enterobacteriaceae, which presumably belong to the core microbiota, were detected in high relative abundance in the gut and frass, indicating a functional role of these microbes, especially the protection against pathogens. We conclude that CPC may be suitable as an inexpensive and environmentally sustainable feed for the industrial rearing of black soldier flflies.
黑兵飞幼虫(Hermetia illucens,双翅目:Stratiomyidae)用于将有机侧产物生物转化成有价值的化合物,例如蛋白质,脂质和甲壳素。然而,与农业和水产养殖中的传统蛋白质生产系统相比,养殖昆虫的经济竞争力取决于大量廉价昆虫饲料的可用性。压榨棉籽饼(CPC)是棉花生产的一种副产品,富含蛋白质和脂质,但由于抗营养倍半萜类棉酚的存在,不适合作为几种养殖动物的饲料,除了反刍动物。在这里,我们测试了CPC作为黑兵飞幼虫的饲料,并研究了这种饮食对肠道微生物组的影响。在CPC上生长的幼虫正常发育,甚至表现出较短的生命周期,但在幼虫发育结束时比在鸡饲料上生长的对照幼虫更小。幼虫对不同饮食的适应性是由它们的多功能肠道微生物组介导的,这有助于消化和解毒。因此,我们使用amplicon测序来分析与细菌和真菌群落相关的
工业园区污水及经生物反应器处理后的污水氨氮、有机氮及化学需氧量(COD)的测定
使用格哈特凯氏定氮仪测定药用汉麻(大麻)中氮含量
使用格哈特凯氏定氮仪测定水溶性复合氮磷肥料NPF中氮含量
