方案下载应用领域 | 制药 |
检测样本 | 中药材和饮片 |
检测项目 | 含量测定>蛋白质 |
参考标准 | EUROPEAN PHARMACOPOEIA 6.0 2.5.33 Total protein, Method 7 |
7种蔷薇属药用植物的抗氧化能力、重金属、矿物质和蛋白质含量的评价Assessment of Antioxidant Capacity, Heavy Metal, Mineral and Protein Contents of Some Medicinal Plants 7种蔷薇属药用植物的叶片烘干粉碎后使用格哈特公司 全自动杜马斯定氮仪 杜马森Dumatherm检测氮和蛋白质含量 称量50毫克植物粉末样品在锡杯中在仪器中900ºC 燃烧检测蛋白质含量 The leaves were dried in the dark at room temperature (22 ±2°C) and were ground with a grinding mill . After the dried plant samples were ground, nitrogen and protein amounts were determined with the Dumatherm Nitrogen-Protein device (Gerthardt Analytical System, Germany). 50 mg of pulverised plant sample was weighed and burned in tin cups at 900ºC in the device to determine the amount of protein.
50 mg of pulverised plant sample was weighed and burned in aluminium tin cups at 900ºC in the device to determine the amount of protein.
工业园区污水及经生物反应器处理后的污水氨氮、有机氮及化学需氧量(COD)的测定
使用格哈特凯氏定氮仪测定药用汉麻(大麻)中氮含量
使用格哈特凯氏定氮仪测定水溶性复合氮磷肥料NPF中氮含量
