方案下载应用领域 | 材料 |
检测样本 | 薄膜材料 |
检测项目 | |
参考标准 | HJ 557-2010 固体废物 浸出毒性浸出方法 水平振荡法 |
混合Na-A沸石氧切薄膜复合纳滤膜去除Cr(III)三价铬Hybrid Na-A Zeolite Oxycut Residue Thin Film Composite Nanofiltration Membrane for Cr (Iii) Removal 使用格哈特振荡器100rpm振荡24小时
2.3.2 Leaching tests A heavy metal leaching test from fly ash and Na-A zeolite was investigated in aqueous solutions in both acid and alkaline media, adjusted by hydrochloric acid and sodium hydroxide solutions. Suspensions containing 0.05 g of zeolite and fly ash, in 10 ml of solution at pH values of 2, 5, 7, 9, and 11, were agitated for 24 h at 100 rpm (Gerhardt Laboshake). The pH of the leachate was measured using a pH meter (Mettler-Toledo), and samples were filtered and analyzed by ICP-MS (Perkin Elmer ICP-MS, Optima 8300). 使用格哈特振荡器100rpm振荡24小时
2.3.3 Adsorption studies of Cr (III) Batch tests were conducted to determine the metal adsorption by shaking at 100 rpm (Gerhardt Laboshake), 0.05 g of zeolite, and 10 ml of Cr3+ solutions with different concentrations. The experiments were performed in closed flasks at room temperature (25 +- 2⁰ C) in duplicate, pH values (Mettler Toledo, pH-meter) were monitored at each sample withdrawal. Isotherm data were obtained after reaching an equilibrium time of 24 h. All samples were filtered using a membrane of 0.45 m pore size prior to measurements of Cr3+ concentrations by ICP-MS (Perkin Elmer ICP-MS, Optima 8300). The adsorption capacity (qe) of zeolite was calculated by Eq. (1) where C0 and Cf are the initial and final metal ion concentrations, respectively, Va is the aqueous phase volume and M is the weight of zeolite used.
工业园区污水及经生物反应器处理后的污水氨氮、有机氮及化学需氧量(COD)的测定
使用格哈特凯氏定氮仪测定药用汉麻(大麻)中氮含量
使用格哈特凯氏定氮仪测定水溶性复合氮磷肥料NPF中氮含量
