方案下载应用领域 | 环保 |
检测样本 | 废水 |
检测项目 | |
参考标准 | / |
碳基纳米材料是废水处理工艺的理想材料Carbon-Based Nanomaterials as Promising Material for Wastewater Treatment Processes 使用格哈特RO500振荡器150 rpm振荡24小时 Shaker (24h,150 rpm; Laboshake Gerhardt Typ RO 500, Germany)
This process was based on a mixture of raw wastewater and excess sludge supernatant collectedfrom "Jamno" Wastewater Treatment Plant("J"WTP; located within Koszalin city area, Poland).Moreover, we used activated sludge biomass obtained from the biological aeration tank of"J"WTP. Thebatch experiment was performed within conical flask containers (250 mL) placed on the shaker (24h,150 rpm; Laboshake Gerhardt Typ RO 500, Germany) at room temperature. Using this experimentalsetup several mixtures were investigated including:
(1) 100 mL mixture of raw wastewater and sludge supematant (1:1; v/v) combined with givencarbon material at dose 500 mg/L. After reaction time (24 h) the resulting liquid was filtrated usingcellulose filter (diameter 125 mm, medium type, producer Chemland, Poland) and analyzed.
(2) 75 mL mixture of raw wastewater and sludge water (1:1; v/v) combined with 75 mL of activated sludge (concentration 3.8 g/L) sample and given carbon material at dose 500 mg/L. After reaction time (24 h) resulting suspension was spitted into two parts. One volume (70 mL, approximately) was filtrated as above and the second volume (80 mL, approximately) was used for analysis of activated sludge parameters.
工业园区污水及经生物反应器处理后的污水氨氮、有机氮及化学需氧量(COD)的测定
使用格哈特凯氏定氮仪测定药用汉麻(大麻)中氮含量
使用格哈特凯氏定氮仪测定水溶性复合氮磷肥料NPF中氮含量
