资料下载This technical note addresses two aspects of electrochemical testing using the Rotating Cylinder Electrode (RCE). First, the fundamental hydrodynamic behavior at a rotating cylinder is summarized, including equations which predict the mass transport limited corrosion current at an RCE. Second, a means of selecting the suitable rotation rate for an RCE test is discussed, with emphasis being placed on matching a particular rotation rate to a particular flow velocity in a smooth pipe. In addition, a bibliography of significant reports regarding the RCE is provided. Introduction Corrosion processes can accelerate significantly under extreme environmental conditions such as high temperature, high pressure, and turbulent fluid flow.When troubleshooting a field corrosion problem, a researcher often needs to return to the lab and reproduce the same (or similar) harsh conditions in a controlled setting. While familiar laboratory equipment for temperature control (ovens, water baths) and pressure control (autoclaves) is generally readily available and easy to use, recreating a fluid flow condition generally poses a larger challenge to the researcher. Laboratory flow loop systems often require complex (i.e., expensive) plumbing, maintenance, and calibration to reliably and reproducibly move fluid past a metal sample. But the need for this type of large-scale laboratory equipment can often be avoided by moving the metal sample with respect to the fluid instead.
燃料电池活化过程对催化性能提升的影响
简介:为了降低质子交换膜燃料电池的制造成本,我们通常会使用颗粒很小但表面积很大的碳颗粒负载催化剂在电极上。这种催化剂在阳极帮助质子很快地传递到膜上,而在阴极则协助产生水。质子导电电解质如Nafion在这个过程中扮演着重要角色,它有效地将质子在催化剂层内传递。质子导电电解质的存在让催化剂能在三维空间里发挥作用,只有那些直接接触膜的催化剂才能发挥作用,其他部分催化剂会被浪费掉。
燃料电池测试系统的背压、相对湿度、空气化学计量比对测试结果的影响
简介:解决掉PEMFC的高成本以及耐用性有限、稳定性差的问题,就成为了实现商业化应用的关键。研究发现,PEMFC的性能与相对湿度、背压、氢气和气体化学计量比、电池温度等各种操作参数密切相关。
百年极谱,系列4——极谱法在废水中铊含量检测的应用
简介:2021年是捷克化学家Jaroslav Heyrovsky(1890-1967)发明极谱法的第100周年。正是极谱法的发明,才使得传统的电化学伏安法在分析化学中得到了广泛应用。 谈起“铊”元素,很多人对它并不熟悉。铊是一种高度分散的稀有重金属元素,被广泛应用于高能物理、超导材料、医药卫生、航天、电子、通讯、军工、化工催化等领域,是非常重要的工业材料之一。但同时,铊也是一个典型的剧毒元素,其毒性远超我们常听说的汞Hg、镉Cd、铜Cu、铅Pb等重金属而近似于砷As,历史上曾多次发生过铊中毒投毒事件。铊和其他毒药一样,都是从起初的“误为医药”成为之后的毒药。铊化合物在被放进耗子药之前,被病人们吃了近四十年。
WD100电化学工作站:Mott-Schottky曲线、阻抗(EIS)、光电流(i-t)的理想选择
简介:美国PINE公司新一代WaveDriver100电化学工作站/恒电位仪/恒电流仪/零电阻电流计可用于两电极、三电极模式,具有交流阻抗功能(EIS),可以广泛地应用于燃料电池、锂电池、太阳能电池、隔膜、超级电容器、传感器、涂层、缓蚀剂、物理化学等研究领域
电催化反应实验中的常见“活性”
简介:电解水、燃料电池等研究中重要的反应OER,ORR,HER,HOR都需要高活性的电催化剂,而建立合理的活性度量、正确评估催化剂电催化性能对寻找最佳电催化剂具有重要意义。我们通常将固有活性定义为比活性,即单位催化剂表面积上通过的电流。因此,对电催化剂比活性的精确评估高度依赖于催化剂表面积的可靠测量。 在进行电催化活性的评价测试中,经常会遇到以下三个指标:电化学活性面积(ECSA,Electrochemical Surface Area)、质量比活性(MA,mass activity)、面积比活性(SA,specific activity)。 美国PINE WaveDriver200双恒电位仪是美国PINE电化学工作站中带有阻抗功能的双恒产品,具有自带11种旋转测试方法、自带EIS软件库无需拟合、DEBE/DECV模块等“九大功能”。
美国PINE_旋转圆盘电极装置_MSR(经典款)_RRDE电化学仪器
美国PINE_旋转圆盘电极装置_Wave Vortex(创新款)_电化学仪器_理化香港公司
数字型旋转圆盘电极装置_DSR旋转环盘电极_旋转圆盘圆环电极_RRDE
美国PINE_WaveDriver200电化学工作站_旋转圆盘电极_理化香港公司
美国PINE-WaveDriver100电化学工作站_旋转圆盘电极_理化香港公司
980系列_燃料电池测试系统_手动背压_氢电池测试_理化公司
980系列_燃料电池测试系统_自动背压_氢电池测试_理化公司
意大利Amel 4330极谱仪
意大利Amel 4330/P极谱仪
PINE高温旋转圆盘电极/RDE电极
旋转圆盘电极(E4 RDE 可换盘)旋转玻碳盘
E2快速电极_旋转圆盘电极配件_RDE电化学测试_美国PINE
旋转圆盘圆环电极(E6 RRDE高温)
旋转圆柱电极(RCE)
非旋转杆(E5 RDE)
