方案下载应用领域 | 钢铁/金属 |
检测样本 | 钢材 |
检测项目 | 可靠性能>其他 |
参考标准 | -- |
The electrochemical corrosion behavior of X65 pipeline steel in the simulated oil/water emulsion was investigated under controlled hydrodynamic and electrochemical conditions by rotating disk electrode technique. Results demonstrated that mass-transfer of oxygen plays a significant role in the cathodic process of steel in both oil-free and oil-containing solutions. Electrode rotation accelerates the oxygen diffusion and thus the cathodic reduction. The higher limiting diffusive current density measured in oil-containing solution is due to the elevated solubility of oxygen in oil/water emulsion. The anodic current density decreases with the increase of electrode rotating speed, which is attributed to the accelerated oxygen diffusion and reduction, enhancing the steel oxidation. Addition of oil decreases the anodic dissolution of steel due to the formation of a layer of oily phase on steel surface, increasing the reaction activation energy. The steel electrode becomes more active at the elevated temperature, indicating that the enhanced formation of oxide scale is not sufficiently enough to offset the effect resulting from the enhanced anodic dissolution reaction kinetics. The corrosion reaction mechanism is changed upon oil addition, and the interfacial reaction is activation-controlled, rather than mass-transfer controlled. When sand particles are added in oil/water emulsion, there is a significant increase of corrosion of the steel. The presence of sands in the flowing slurry would impact and damage the oxide film and oily film formed on the steel surface, exposing the bare steel to the corrosive solution.
DSR产品理念顺应数字化潮流,采用当下先进的数字控制芯片技术,有效地减小了体积,提高了信号抗干扰能力。DSR采用数字编码器电机控制,通过反馈实际值与期望值来进行比较,并进行误差补偿和调整,以实现精确的运动控制。能够准确地控制电机的位置、速度和方向,实现精确控制。DSR数字信号技术抗干扰能力保障实验不受环境信噪干扰,性能稳定,更适合中国实验室操作习惯。
二氧化锰/C复合材料的电化学电容特性研究
EIS交流阻抗法在材料膜抗腐蚀中的应用
ORR/OER测试中未补偿电阻Ru的测试及IR补偿技术
数字型旋转圆盘电极装置_DSR旋转环盘电极_旋转圆盘圆环电极_RRDE
DC 980 PEM 燃料电池测试系统(手动背压)
DC 980系列 研究型燃料电池测试系统(桌面式)
意大利Amel 4330极谱仪
意大利Amel 4330/P极谱仪
E2快速电极_旋转圆盘电极配件_RDE电化学测试_美国PINE
RHE可逆氢参比电极
E5GC 玻碳盘电极_旋转圆盘电极配件_电化学测试
环境磁场检测与分析仪SC11
电镜屏蔽/主动消磁系统SC20
电镜屏蔽/主动消磁系统SC22
Spicer主动消磁器SC24
环境磁场检测与分析仪
显微镜减震/光学平台/隔振平台(理化公司)
隔振平台/减振平台/电镜减振台/MinusK
