资料下载Terahertz (THz) radiation is located in the spectral region ~0.1-10 THz (~3 mm - 30 μm, 3 cm-1 - 300 cm-1) between the microwave and mid infrared range of the electromagnetic spectrum. In comparison with visible or infrared waves, THz radiation can penetrate into organic materials such as skin, plastics, cloth, or paper products. Because of low photon energy involved, it does not cause any damage associated with ionizing radiation ( e.g. X-rays). THz waves do not penetrate into metals. These properties can be used in process (e.g. drugs manufacturing) and quality control as well as in THz imaging. It is also of great current interest for such applications as safety control, packaging inspection, semiconductor characterization, chemical composition analysis, and biomedical investigations, with great promise for spectroscopy, defense imaging, and security applications. Traditionally for THz applications we use High Resistivity Float Zone Silicon (HRFZ-Si) as it is the most investigated substance for operating within this range and has a good transmission performance. In parallel with this material we have been investigating other materials which also can be utilized in THz range. Below you can see transmission spectra and other characteristics of materials we use for THz optics production. Measurements in THz region were made at ABB FTIR spectrometer Bomem DA3 and Bruker IFS 125HR (measure of inaccuracy is 2-3% below 100 μm and 4-5% over 100 μm). Measurements in near infrared range were made at Perkin Elmer “Lambda- 9” (measure of inaccuracy < 0.5%).
Pluto 空间光调制器在OAM 方向的应用
简介:Pluto 空间光调制器在OAM 方向的应用 涡旋光场由于具有轨道角动量,在量子信息编码,粒子旋转与控制,超分辨显微以及光 镊领域都有巨大的研究价值。也是近年来广大科研工作者研究的一个重要方向。 在涡旋光场的研究中,光学涡旋阵列是一个重要研究方向,其在多微粒操控、高容量量 子通讯等领域具有优势。目前,产生涡旋阵列的方法主要有三种:1、利用特殊微结构材料 产生;2、利用达曼光栅的不同衍射级产生;3、利用多光束干涉产生。 这三种方法中,多光束干涉产生方法原理简洁,得到了较为广泛的研究。若采用涡旋光 束作为叠加光束,该技术可简化为双光束干涉,并且能产生一种特殊的“摩天轮”式环形涡 旋阵列,形成具有前沿应用价值的均匀环形光陷阱,如应用于原子捕获、量子兼并气体及莫 特绝缘体转变等方面。然而,该技术需要两束特定拓扑荷值的涡旋光束干涉,一旦选定,其 空间结构几乎不能调控;此外,其干涉光路结构较为复杂、光路调整难度较大
如何使用空间光调制器SLM 生成涡旋光束
简介:涡旋光场由于具有轨道角动量,在量子信息编码,粒子旋转与控制,超分辨显微以及光 镊领域都有巨大的研究价值。也是近年来广大科研工作者研究的一个重要方向。 在涡旋光场的研究中,光学涡旋阵列是一个重要研究方向,其在多微粒操控、高容量量 子通讯等领域具有优势。目前,产生涡旋阵列的方法主要有三种:1、利用特殊微结构材料 产生;2、利用达曼光栅的不同衍射级产生;3、利用多光束干涉产生。 液晶空间光调制器是一类将信息加载于一维或者二维数据场上,以便有效利用的光的并 行性,固有速度和互连能力的器件。一般来说,空间光调制器由许多独立单元组成,在空间 上排成二维阵列结构,每个单元独立接受光信号或者电信号的控制,改变光的振幅,相位, 或者偏振态等。 目前来说,我们Holoeye 空间光调制器以其优良的品质高性价比目前在市场上占很大比 例。本文件将用到Holoeye 旗下购买率更高的pluto 这一款进行说明。这一款主要有以下特 点,高分辨率,高衍射效率,高填充因子,高损伤阈值等等
空间光调制器选型注意事项
简介:液晶空间光调制器以其灵活可调应用广泛等优势被广大的科研工作者青睐。目前主要的应用 领域有:全息成像,光场调控,光镊,超分辨显微成像,飞秒脉冲整形等。 客户在对SLM 进行选型的时候,首先要根据自己的实际应用出发,了解空间光调制器的一 些性质。
OS 4500光学参量振荡器
简介:OS 4500光学参量振荡器是一个紧凑的、集多功能于一身的连续激光光源,结合了优异的光谱特性与超宽调谐范围。具有单频运行、窄线宽、低噪声 及优异光束质量等特点,使其能理想地用于高分辨光谱学及其它红外光谱区需要精密计量的诸多应用。 OS 4500光学参量振荡器配备了一个集成泵浦激光器以及电路稳定控制。通过非线性晶体(掺铌酸锂氧化镁)的周期性极化转换输出信号光(1.38 - 2.00 μm)与闲频光(2.28 - 4.67 μm)。晶体内置于光学谐振腔内实现光学参量振荡,腔内标准具(ICE)确保稳定的单频运行输出。信号光和闲置光辐射是通过在单晶体上整合多个极化周期而实现的。无需更换任何光学组件,系统便可以调谐到所需要的频率输出。
Widely tunable and narrow-linewidth radiation for nearto
简介:泵浦增强连续波光学 参数振荡器(PE cw-OPO)是商业上的 自2000年开始供货。泵浦在1064 nm,信号和 惰轮发射范围为1380-2000nm和2280-4670 在不改变任何光学的情况下实现nm。 狭窄 到目前为止,已经证明了线宽<10 kHz。 一个 特殊谐振器设计提供更高的频率 调整品质。 PE cw-OPO已应用于 痕量气体检测领域,分子光谱学, 计量和材料调查。 关键词:非线性光学,激光光谱学
红外连续可调OPO激光器 德国 Qioptiq
Phasics波前探测器SID4
FROG超短脉冲测量仪+自相关仪+Swamp optics+8-20-USB
Energetiq 激光驱动白光光源LDLS EQ-99XFC
红外相机
Onefive Katana 通用型脉冲激光器
Onefive Origami 低噪声孤子飞秒光纤激光器
美国electrophysics公司 红外相机 7290A
Lyncee 数字全息显微镜 DHM R2100
electrophysics 红外热像仪 ATOM80
OKO N50mm 37/79/109通道压电变形镜(PDM)
Beam Analyzer光束质量分析仪
中红外光谱仪
光纤激光器
光纤放大器
