资料下载真空中两块平行金属板之间存在某种吸引力,这种吸引力被称为卡西米尔力。通常情况下,这种力只会导致物体“相互吸引”,而非“相互排斥”。美国科学家最近在实验中成功将这种力转变为斥力,并对其进行了测量。 这项研究由哈佛大学工程和应用科学学院教授费代里科·卡帕索领导。科学家发现,真空中两块平行金属板的表面距离小于100纳米时,产生的卡西米尔力十分明显。如果将其中一块金属板置换为硅板,并将它与另一块金属板浸入某些流体中,使它们距离非常接近,此时产生的卡西米尔力便是一种斥力。 为了测量这种斥力,研究人员利用AsylumResearch公司的原子力显微镜组建了一个表面镀金的微型球和一块硅板模拟两个平行平板。在非常微小的距离内,二者的表面被认为是几乎平行的。研究人员将二者浸入无色油状液体溴苯中,使二者相互靠近,直至卡西米尔斥力开始发挥作用。此时,研究人员通过测量两者距离变动时微型球的偏转来测量卡西米尔斥力。 卡西米尔力非常微弱,但却可以使纳米及毫米尺度的电子元件粘合在一起。例如,在计算机芯片工业,当硅片上的元件小到一定尺度,它们就会粘在一起。如果将卡西米尔引力转化为斥力,这种现象就不会发生。而且相关技术的应用前景将十分广阔,例如可以用于制造无摩擦轴承等理想设备。
水凝胶机械性能测试
简介:The Piuma Nanoindenter is a new and versatile instrument for the characterization of the mechanical properties of soft hydrogels. Check our recently released application note on agarose and gelatin to get an impression about some essential measurements the Piuma can perform! And it does not stop here: very soft hydrogels, other biomaterials, tissues, cell sheets and even single cells are all part of the Piuma domain, which provides researchers with unparalleled accuracy and ease of use in mechanical experiments.利用piuma生物纳米压痕研究水凝胶的力学性质,包括杨氏模量,表面形貌等性质。
骨水泥的杨氏模量测试
简介:Biosilica, a biocompatible, natural inorganic polymer that is formed by an enzymatic, silicatein-mediated reaction in siliceous sponges to build up their inorganic skeleton, has been shown to be morphogenetically active and to induce mineralization of human osteoblast-like cells (SaOS-2) in vitro. In the present study, we prepared beads (microspheres) by encapsulation of β-tricalcium phosphate [β-TCP], either alone (control) or supplemented with silica or silicatein, into the biodegradable copolymer poly(D,L-lactide-co-glycolide) [PLGA]. Under the conditions used, ≈5% β-TCP, ≈9% silica, and 0.32 μg/mg of silicatein were entrapped into the PLGA microspheres (diameter≈800 μm). Determination of the biocompatibility of the β-TCP microspheres, supplemented with silica or silicatein, revealed no toxicity in the MTT based cell viability assay using SaOS-2 cells. The adherence of SaOS-2 cells to the surface of silica-containing microspheres was higher than for microspheres, containing only β-TCP. The formation of new bone induced by the microspheres is also evident from measurements of the stiffness/reduced Young's modulus of the regenerated bone tissue. The reduced Young's modulus of the regenerating bone tissue around the implants was markedly higher for the silica-containing microspheres (1.1 MPa), and even more for the 1:1 mixture of the silica- and silicatein-containing microspheres (1.4 MPa), compared to the β-TCP microsphere controls (0.4 MPa). We propose that based on their morphogenetic activity on bone-forming cells in vitro and the results of the animal experiments presented here, silica/ biosilica-based scaffolds are promising materials for bone repair/regeneration.
纳米压痕仪与压电力显微镜联用
简介:纳米压痕仪与压电力显微镜联用 结合纳米压痕的压电力显微镜测试(详见PFM应用手册)  力反馈 (应力控制)以及压痕深度(应力控制)  力学实时分析  力学 vs 位置  恒幅载荷  准静态实验法: 压痕蠕变, 应力松弛  动态测试
纳米压痕仪资料PPT
简介:Asylum’s MFP Nanoindenter 纳米压痕仪是一款为市场所认可的商业化纳米级压痕仪,是业内第一款基于原子力显微镜的压痕仪器。通过结合顶级原子力显微镜的传感器,为该款纳米压痕模块提供了超过其他纳米压痕系统所无法企及的准度、精度以及敏感度。 纳米压痕仪通过与原子力显微镜的结合,利用原子力显微镜卓越的形貌观察能力同时对压头和压痕结果的测试,可以提供独一无二的定量压痕接触区域计算能力,提供业内最准确的确定接触区域 ,获得间接估算材料性质所没有的精度。特有的一维柔性铰链的被动驱动方式从而使得漂移和深度测试中的其他错误得到最小化。压入过程中的热漂移效应全自动扣除,测量结果更加真实、可靠。 高性能的样品加载系统和传感技术使得nanoindeter纳米压痕仪成为了最多样化的纳米力学表征工具,是科学家、工程师和其他各领域用户的最佳选择。在摩擦、模量成像、动态力学分析、薄膜、陶瓷、复合物、聚合物、微机电系统、生物和金属等领域都有广泛应用。符合 ISO/IEC 17025.1以及ISO 14577-22国际标准。 行业应用:材料、生物、化学、物理相关的政府检测机构、科研院所、高校和大型企业研究机构
纳米压痕仪操作手册
简介:Asylum’s MFP Nanoindenter 纳米压痕仪是一款为市场所认可的商业化纳米级压痕仪,是业内第一款基于原子力显微镜的压痕仪器。通过结合顶级原子力显微镜的传感器,为该款纳米压痕模块提供了超过其他纳米压痕系统所无法企及的准度、精度以及敏感度。 纳米压痕仪通过与原子力显微镜的结合,利用原子力显微镜卓越的形貌观察能力同时对压头和压痕结果的测试,可以提供独一无二的定量压痕接触区域计算能力,提供业内最准确的确定接触区域 ,获得间接估算材料性质所没有的精度。特有的一维柔性铰链的被动驱动方式从而使得漂移和深度测试中的其他错误得到最小化。 高性能的样品加载系统和传感技术使得nanoindeter纳米压痕仪成为了最多样化的纳米力学表征工具,是科学家、工程师和其他各领域用户的最佳选择。在摩擦、模量成像、动态力学分析、薄膜、陶瓷、复合物、聚合物、微机电系统、生物和金属等领域都有广泛应用。 行业应用:材料、生物、化学、物理相关的政府检测机构、科研院所、高校和大型企业研究机构 纳米压痕仪操作手册
