方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
ABSTRACT We report the first nanoindentation studies of well-ordered nanocrystal supercrystals composed of 7 nm lead sulfide nanocrystals stabilized with oleic acid ligands as a model system. Their modulus and hardness were found to be similar to hard polymers at 1.7 GPa and 70 MPa, respectively, and the fracture toughness was 40 KPa/m1/2, revealing the brittle nature of these materials. The mechanical properties are dominated by the organic capping agents surrounding the inorganic cores. The close-packed structure distributes stress evenly increasing the modulus and hardness. The relatively short ligands are not likely to be highly interdigitated leading to low dissipation during crack propagation and a low-fracture toughness value.
