资料下载研究领域:锂离子电池电极材料 交流阻抗频率范围:5000Hz - 0.1Hz The cycling performance of a LiNi0.8Co0.15Al0.05O2 cathode at 60°C was substantially improved by direct SiO2 dry coating. The SiO2-coated cathode was obtained from firing of the mixture consisting of SiO2 nanoparticles and the cathode powders with a weight ratio of 99:1 at 700°C for 5 h. The first discharge capacity of the coated cathode was 172 mAh/g, whereas the uncoated one showed 182 mAh/g at 60°C. However, the coulombic efficiency of the coated sample was 95%, which was 2% higher than that of the uncoated sample. Moreover, the discharge capacities of the coated cathode at 60°C was about 2.5 times larger than those of the uncoated sample at rates of 0.5 and 1C, showing 146 and 109 mA/g, respectively. This capacity improvement at 60°C is related to the fact that the highly distributed Si element near the surface, as a type of solid solution with LiNi0.8Co0.15Al0.05O2, diminishes the side reactions of the cathode and electrolyte at 60°C.
染料敏化太阳能电池DSSC
简介:Investigation on photovolatic performance of hollow sphere/nanoparticle composite TiO2 electrodes for solid state dye sensitized solar cells. Dynamic Response of Charge Transfer and Recombination at Various Electrodes in Dye-sensitized Solar Cells Investigated Using Intensity Modulated Photocurrent and Photovoltage Spectroscopy.
锂离子电池电解质
简介:Nature SR-JLU-Integrated Solid-Nanoporous Copper-Oxide Hybrid Bulk Electrodes for High-performance Lithium-Ion Batteries
阻抗文献7
简介:Performance of non-porous graphite and titanium-based anodes in microbial fuel cells
阻抗文献6
简介:Influence of CO2 on ionic conductivity of anion exchange membrane for alkaline DMFCs
阻抗文献5燃料电池
简介:Electrochemical impedance spectroscopy (EIS) is in potential a powerful tool for the in depth analysis of microbial fuels cells (MFCs). To prevent the risk of drawing false conclusions from invalid EIS measurements we investigated the feasibility of this method on an MFC by checking: linearity, causality, stability and finiteness. EIS application under steady state conditions was partly feasible. For further application EIS on MFCs we recommend to: (1) use the constant anode or cathode potential measurement mode with a fast couple at the counter electrode; (2) record the polarization curve and measure at different amplitudes to check the linearity condition; (3) perform preliminary measurements to reveal measurement presets; (4) apply prolonged pretreatment to facilitate the stability criterion; (5) perform duplicate measurements to examine the stability; (6) use a broad frequency range to validate the finiteness criterion; (7) use a statistical based validation check based on the Kramers-Kronig transformation.
