资料下载研究领域:锂离子电池电极材料 交流阻抗频率范围:500kHz - 0.01Hz Nanoparticle–nanorod core–shell LiNi0.5Mn1.5O4 spinel cathodes for Li-ion batteries were prepared using a hollow MnO2 precursor. The core and shell parts consisted of nanoparticle 100 nm and nanorod assemblies, respectively. The core–shell cathode exhibited greatly improved discharge capacities compared to nanoparticles prepared by a sol–gel method. The core–shell spinel exhibited discharge capacities of 121 and 100 mAh/g at 0.1C and 7C rates, respectively, whereas a spinel cathode prepared by a sol–gel method exhibited 99 and 80 mAh/g at those respective rates. In addition, the core–shell spinels demonstrated an energy density value that was enhanced by 52% to 1.6 Wh/cm3 compared to an analogous sample prepared by a sol–gel method, which showed a value of 0.9 Wh/cm3.
染料敏化太阳能电池DSSC
简介:Investigation on photovolatic performance of hollow sphere/nanoparticle composite TiO2 electrodes for solid state dye sensitized solar cells. Dynamic Response of Charge Transfer and Recombination at Various Electrodes in Dye-sensitized Solar Cells Investigated Using Intensity Modulated Photocurrent and Photovoltage Spectroscopy.
锂离子电池电解质
简介:Nature SR-JLU-Integrated Solid-Nanoporous Copper-Oxide Hybrid Bulk Electrodes for High-performance Lithium-Ion Batteries
阻抗文献7
简介:Performance of non-porous graphite and titanium-based anodes in microbial fuel cells
阻抗文献6
简介:Influence of CO2 on ionic conductivity of anion exchange membrane for alkaline DMFCs
阻抗文献5燃料电池
简介:Electrochemical impedance spectroscopy (EIS) is in potential a powerful tool for the in depth analysis of microbial fuels cells (MFCs). To prevent the risk of drawing false conclusions from invalid EIS measurements we investigated the feasibility of this method on an MFC by checking: linearity, causality, stability and finiteness. EIS application under steady state conditions was partly feasible. For further application EIS on MFCs we recommend to: (1) use the constant anode or cathode potential measurement mode with a fast couple at the counter electrode; (2) record the polarization curve and measure at different amplitudes to check the linearity condition; (3) perform preliminary measurements to reveal measurement presets; (4) apply prolonged pretreatment to facilitate the stability criterion; (5) perform duplicate measurements to examine the stability; (6) use a broad frequency range to validate the finiteness criterion; (7) use a statistical based validation check based on the Kramers-Kronig transformation.
