方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
研究领域:锂离子电池电极材料 交流阻抗频率范围:500kHz - 0.01Hz Nanoparticle–nanorod core–shell LiNi0.5Mn1.5O4 spinel cathodes for Li-ion batteries were prepared using a hollow MnO2 precursor. The core and shell parts consisted of nanoparticle 100 nm and nanorod assemblies, respectively. The core–shell cathode exhibited greatly improved discharge capacities compared to nanoparticles prepared by a sol–gel method. The core–shell spinel exhibited discharge capacities of 121 and 100 mAh/g at 0.1C and 7C rates, respectively, whereas a spinel cathode prepared by a sol–gel method exhibited 99 and 80 mAh/g at those respective rates. In addition, the core–shell spinels demonstrated an energy density value that was enhanced by 52% to 1.6 Wh/cm3 compared to an analogous sample prepared by a sol–gel method, which showed a value of 0.9 Wh/cm3.
