应用高效逆流色谱技术一次分离两类顺反异构体
2013/06/28   下载量: 4
方案下载
应用领域 石油/化工
检测样本 其他
检测项目
参考标准
Four flavonoids, isoastilbin, astilbin, isoengelitin, and engelitin were isolated and purified simultaneously from Smilacis Glabrae Roxb. for the first time by high performance counter-current chromatography using a system consisting of n-hexane–n-butanol–water (1:2:3, v/v/v). A total of 392.6 mg of astilbin, 71.4 mg of isoastilbin, 47.4 mg of engelitin, and 10.3 mg of isoengelitin were purified from 1.89 g of the ethyl acetate extract of Smilacis Glabrae Roxb. in six runs, each at over 94.51% purity as determined by HPLC. The structures of the four compounds were identified by their retention time, the LC-ESI-MSn in the negative ion mode, and confirmed by 1H-NMR experiments. The characteristic LC-ESI-MS fragmentation patterns of the four compounds were discussed.
方案下载
配置单
文献贡献者
弗士达仪器
铜牌会员第17年
查看全部资料
相关方案
当前位置: 弗士达仪器 方案 应用高效逆流色谱技术一次分离两类顺反异构体
