方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Phenylketonuria (PKU) is a genetic inborn error of metabolism, that is detectable during the first days of life with appropriate blood testing. The absence or deficiency of an enzyme that is responsible for processing the essential amino acid phenylalanine characterizes PKU. Without treatment, most infants with PKU develop mental retardation. Early detection of PKU can allow patient treatment to prevent mental retardation, as well as other associated problems. Treatment consists of a carefully-controlled pherestricted diet begun during the first days or weeks of life. Frequent blood monitoring of PKU patients is necessary, especially during infancy and early childhood when it is important to keep the blood phenylalanine levels at the safest level. Biochrom Amino Acid Analysers are widely used for the routine analysis of phenylalanine. Clinical laboratories have a continuous requirement for analyses of large numbers of samples. Rapid, accurate analysis is critical to meet the demand of the screening programmes. Improvements in peak resolution, accuracy, run times, and quantitation by using a dedicated instrument has enabled clinical laboratories to screen large numbers of samples per week. Using the Biochrom 30 Amino Acid Analyser phenylalanine can be rapidly and accurately quantified using norleucine as internal standard. The separation is carried out using a 20 cm x 4.6 mm high performance physiological column using buffer DII predominantly. The program enables 25 analyses to be performed a day. In addition tyrosine and homocystine are also well resolved thus enabling screening for the other metabolic diseases such as Tyronisis and Homocystinuria.
如何选择氨基酸分析仪
水活度仪在水酸盐钻井液分析中的应用
